Current while timer fired prematurely
Check if the timer has has been set properly while creation of the port. The time stamp is erroneous. Reset the timers. show lacp show lacp counters show lacp member-port <port> {detail}
Notice
The current while timer expired prematurely for port %port% Expired after %sec% seconds %usec% microseconds. Timeout: %timer% seconds
| Name | Type |
| port | String |
| sec | uInt32 |
| usec | uInt32 |
| timer | uInt32 |
